Seat Ibiza (6L): Air suspension and more.....SPLITTING/FOR SALE
R1ch85
1/4mile - 13.935 @ 100.54
Nov 9, 2006
1,675
Bristol
Impressed with how quick you get on with things. Glad you dropped the front, nothing worse than reverse rake. Ahhh FK's, my friend Dave always gloats that he has a set :censored:! They're certainly worth the money by the look of it.
Well, I paid a small fortune for mine as they're stainless and adjustable dampening, however they do go nice and low, and also when I lowered the fronts more this afternoon, nothing was seized up at all! :D Hardest part was lining the wheel up with the holes for refit lol :p
I chopped away at the arch as much as I thought I needed, but its clearly not enough. Been out this evening and theres rubbing over relatively small bumps now :( kinda embarrassing when people look round at that lol :redface:
I think I'll have to drive as it is for a bit so I get a fresh idea of where the rubbing is and then revisit with a sharp knife!
Nov 24, 2007
543
Swansea
Photograph was taken midnight at Swansea Univeristy:
FIGARATE
jus read through this thread mate loving them rims top notch job
Nov 24, 2007
543
Swansea
Saw this car at Bristol Volksfest. Looks proper mint in the flesh too! :)
Man I burnt like crazy that day, but still an awesome show.
Since Volksfest its sitting slightly lower and fitted 195/40/16 tyres as the previous set rubbed like crazy!
Thanks for the kind comment. Were you on the Vagowners stand that day as I can't remember seeing your R32?
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
It did look good! And yes I was on the vagowners stand. And my R32 was there :) Silver one :)
Just to prove:
Nov 24, 2007
543
Swansea
Shucks! The sun must have blurred my vision :blink: but it looks good from the photographs. A friend of mine has one and it sounds amazing.........determined to buy one in the near future.
Nov 24, 2007
543
Swansea
A brief update.
Car has been in my garage since thursday as the amount of wheel wobble was crazy! So stripped the rear hubs and replaced the bearings at a cost of £40.00 to find that the wobble still remained. Decided to investigate further and I found out that the axle stumps which the bearings slide over have bent by 1mm on each side which could possibly result in my wheel wobble. Collecting a pair of axle stumps later on this afternoon which should get rid of my problem.
On a lighter note, spacers and camber shims have arrived which should be fitted once everything is back to running how it should be. New fitment will be:
Front: 8x16 ET19
Rear: 8x16 ET13
And one of my Carbon clad road bike as it was sat in the garage next to my workstation:
Nov 24, 2007
543
Swansea
BOOM:
The rest will be retrimmed in good time but for now, the rear seats will be stripped and a false floor will be fitted.
The wheels are also at a new offset:
Front 8x16 ET19
Rear 8x16 ET10
rf860
3,575
scotland
BOOM:
Front 8x16 ET19
Rear 8x16 ET10
Woah, that is bright! looks a really good job and good quality leather. Amazing how the seats look a lot more 'beefy' when they are leather :confused: How much did that set you back if you dont mind me asking?
Nov 24, 2007
543
Swansea
Thanks RF860. The seats were trimmed in vinyl so the price was slightly cheaper at £300.00 (I'll admit it was cheaper as I knew the guy). Just need to save for the rear seats to be trimmed now so watch this space.
Spotted the SCN stand on sat at Edition 38 but didn't realy catch any of the owners to have a talk as I have no idea what you guys look like!
Nov 24, 2007
543
Swansea
Thanks man.
No recent shots of the wheels sorry as I'm realy not happy with how it sits as the 6L is a right :censored: to get low! I think Air is the only option and I've been talking to Geoff from Havair for quite some time. So might venture down that route sometime soon.
Wilber
105
Belfast
The 6 series platform is a bitch to get low in general. Air is an option, but a slightly cheaper option would be spring clamps. Mate has em on his MG ZR and hes had no problems so far. That or the option of cutting the springs, which ive contemplated, but really wasnt worth the hassle. Whats the clearance like on the rear inner arch with an 8 inch rim mate?
Nov 24, 2007
543
Swansea
Totally agree with the headache of the 6L platform when lowering! Never thought about spring clamps but I might have a look into it and see what would be expected. Thanks.
I've also thought about cutting the springs but someone pointed out that the dampers might bottom out if I take too much away and I can only guess the same problem would exist with custom springs.
The rear wheels are 8J et 10 so the inner arch clearance is fine with loads of room to spare. Slight poke on the rear but no rubbing at all as the 195/40 sit perfectly inside the arch. Compared to my standard Seat Sport wheels, I have 13mm greater inner clearance and outer position has been extended by 51mm
