There are various threads about this. Your mileage may vary though...does anyone know where i can get the led's for the side lights?
Used H7R for my dipped beam, you can use H7's but they may cause glare due to the leon having reflector lamps. You really should use the "R". As GainfulShrimp suggests i would not use HID on the main beam as the flash will shorten thier life, HIDS also have a warm up time so the flash would not be very good, I would suggest HIDS for the dipped and after market halogen for the main beam. Also go for some LED side lights as the normal bulbe will look very yellow once you put HID's in. Make sure the LEDS are for canbus or else you will have dash warnings for failed bulbs.
Uncle
The H7R capsules have some coating/shield on the lower half of the glass, so that only incidental reflections end up on the bottom half of the reflector, meaning less glare for oncoming vehicles.what is the difference between the H7 and the H7R?
thanks for your guidance im going to take it. they are getting changed for the h7r.
Some people prefer to use H7 capsules but then aim the beams lower, either using the dash control (usually used when the car is towing or under big load), or using the white adjuster just above the headlight unit.
I personally went for the H7Rs.
Neither are as good as proper OEM projectors though...
Just another term for factory-fitted (i.e. Original Equipment). You can retrofit them but they're very expensive compared to the aftermarket kits. Also, to be 100% safe/legal you need to fit the self-levelling equipment and headlight washers... it's not an easy project, sadly.what are the OEM projectors and where can i get them also how much are they cheers?
I can't give you a link/citation but I'm sure the relevant regulations were quoted in one of the many threads about aftermarket HIDs and their dubious legal status, and they said that you need both headlight washers and self-levelling.why do you need the headlight washers? also cant you use the manual headlight adjuster?
Given the number of twits driving about with poorly implemented HID conversions, half-blinding everyone else on the road, it's very likely that MOT regs will be amended to effectively ban many if not all aftermarket kits IMHO. The only way to be absolutely sure that your HIDs will pass any future, stricter, MOT regulations is to buy them factory-fitted with the car. That's my understanding anyway...
Yes, you can use either the manual adjuster (white screw thingey) on the headlamp unit, or the dial on the dash to adjust the lamps as required. I used the little white screw thingeys to adjust mine.
thanks for your advice, think im going to go for the seat ones. was if just under £300 for both headlight units?
