You may also need to set the duration to more than 0 seconds, not sure where, in some adaption somewhere, same module as you turned the leaving home on.
Dan, spot on buddy, i got my fancy chinese cable this morning, faffed about and found exactly what you described above. I think it was Byte 2 in the adaption field of module 09, was set to 0, now set to 40, works a treat.
chirp chirp, loving the Vag-Com, thanks for all the info posted on this guys, good stuff. Had a fault code for exhaust sensor, cleared OK though, prob should get it looked at on next service. Also tried to set the wing mirrors to dip when in reverse, but no worky (think you need memory seats...).
D
