Cont.
Next up was a calliper change.
I'd seen that one of my 4 pots was leaking through the piston seal and rippling the dust seal.
Thankfully one came up for sale on here, bet none of you noticed this one
So for £100 this was bought.
It seems like it is perhaps off of a crashed car as its paintwork is a bit damaged as was the crossover pipe.
After speaking to John (CupraMVR) I found out this pipe is just standard brake pipe and fittings.
I got a local company to make me up 5 of these for £20
I'd also bought braided brake lines.
I had always wanted to do this but never got around to it. As it has been said before the LCR OEM lines are stiff and braided but the Goodridge ones I got from Bill go all the way from the wheel arch brake pipe to the back of the calliper, this eliminates a few connections.
TBH I was pretty worried about doing this, I'm painfully aware how close my track day is and a small
problem would totally feck this for me.
But all went well, it took a few minutes to suss out how best to do this, but once sussed the other side was a breeze.
I dropped the ARB drop link from the strutt to gain access.
there were a few little tweeks done to the OEM set up to account for the new hoses.
Also due to the slight differences due to the brake pad wear sensor, which will get removed.
Where would we be without tywraps, lol
So next up is the fluid bleed.
If this all goes well I have my first track day of the year tonight
