Light at the end of the tunnel??
Well after 3 calls today it feels like I'm getting close to completing my car for my first track day on the 6th of May.
Awesome bits are on there way, should be here in the next few days.
Stealth waiting on bits that should arrive early next week and GB with diff fitted should be back with me end of next week.
Performance 4 plastics are currently making my windows so should also be here for next Friday too.
Then it'll be get the OEM windows and door skins out, fit the new polycarb windows, carefully, lol.
Build back up the intake manifold with the PCV **** deleted out, new green cotton dual cone fitted and and service with new oil.
Drive the car back to my house, drop the gear box, hopefully the clutch is in good shape, fit the new gear box then off for logging my car with the mapper.
Change out leaking caliper for new one, fit braided lines, bleed out old brake fluid and replace with new RBF600.
Drop suspension, grease top mount bushes/bearings, stiffen up the rear upper bump adjuster to rock hard, lol. I'll also raise the ride height 5mm to a 20mm drop from OEM ride height. This will straighten out the slight wishbone angle I have.
The front will get stiffened up too as not really had a chance to mess about with the settings yet.
It's not that I feel that i need any handling
help but the next track day I'll but pushing to the maximum so want to see how good this set up can be.
I've found a place close to me who will corner weight my car for £220. I don't plan to have this done at the start of the year but could be a possibility for the end of the year.
It's gonna be a tight thing as I'm not expecting to have much time off before the track day.
