VCDS / VAG-COM Register - Who's got what and where?
sjolliff
Vag-Com, West Yorkshire?
Mar 21, 2010
73
Halifax, West Yorkshire
Just to let people know.
VCDS (VAG-COM)
Genuine Fully Registered HEX-CAN-USB. Latest Software Used, Covers All VAG Cars 1992-Present
Brighouse, West Yorkshire. I also work in and around the Selby area ATM!
PM if needed
IE:
Full car scans, Fault Finding, Fault clearing, Data Logging, Extras/Options Activating Etc Plus much more, Access To Parts Catalogue + Workshop Manual
Cheers Steve :cheers:
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
Full vcds in retford notts
Guys, ive been asked quite a few times now to do scanning/logging for members on here
seeing as theres no user map for vcds im posting to say i have full vcds in retford notts for users who need scanning, logging, features doing
any models can be done upto present date
available most days.....pm or call/txt me on 07958937929
cheers
KernowFR
Mr Diesel Box
Apr 2, 2010
77
Cornwall
Vag.Com Cornwall
I have VCDS (Vag.com) Hex-Can-Usb 1996-To Date full version
and able to do:
Selective locking
Anti Hi-Jack
Code Clearing
Full Module Scans
Service Reset
ABS Module Wheel sensor speeds
Alarm Chirp On/Off
Maf Checking/Mapping
Shut Down EGR Valve (1.9 Engine)
And full engine checks with charging Voltage
If you want something done then i'm here everyday give me a shout.
processpaul
103
Brighton
Full VCDS Hove East Sussex
Fully registered HEX-CAN-USB VCDS All cars 1992 to present.
Able to do the following:
ECU Logging
Enable/disabled functions such as locking chirps, Long coded functions on >2005 models
Adaptions
Fault code reading
Service resets
Location HOVE East Sussex.
Pm me for assistance.
mikeholroyd
Preston, Lancashire and surrounds
Fully registered genuine Ross Tech HEX+CAN lead and latest software.
PM me if you need any help in the Lancashire / Merseyside area
Mike
Reactions: Woody_72
Pigeon142
137
VCDS (VAG-COM)
Birmingham, Midlands
PM if needed
R44MS K
54
Name Rams
Location East London,
Region I live in East London but my missus lives in Southampton - I can help members in South, East, West London and Southampton (or anywhere on the way!)
Version of VAG-COM FULL version VCDS 10, VDS Pro, vagtacho, EEPROM reader
Abilities you have advanced - Vagcom, autowindows, key coding, miles to empty, illuminated dials , backed up by Audi Mastertech (if advice is needed)
Will you charge - time dependent
Fahid82
Revo stage 1
Oct 26, 2008
306
East Kilbride Glasgow
Ive got a fully registered HEX-CAN-USB VCDS All cars 1992 to present.
I can do
ECU Logging
Adaptions
Fault code reading
Service resets
Location Glasgow
adam_lincs
DJ Extrodinaire...
Aug 27, 2010
106
lincs
I have hex-can-usb running version 805.1 in lincoln area.
on audi-sport.net they had a map (done thru google iirc) that had pin markers for the vcds users, is there an equivalent on here?
i've made one to show as an example but cant post urls... :(
vagcom
I have a registered version of vagcom and cover the whole of South Wales.
I can do all the fancy stuff like anti hijack, alarm chirp, selective locking and knocking off the seat belt beep and also read and clear codes, reset service lights.
Based in MAESTEG.
pm me If needed
Kevin
reflexuk
Future member
Jul 16, 2008
186
Nr Chesterfield Derbyshire
So far used to do
ECU Logging
ECU Adaptation inc Immob, Enable/disable, SEATBELT CHIME, LOCK/UNLOCK CHIRP, LOCK/UNLOCK INDICATOR FLASH, AUTO LOCK/UNLOCK, SELECTIVE UNLOCKING, INTERIOR MOTION SENSORS
ADJUST ALARM/SIREN TONE
Also
THROTTLE BODY ALIGNMENT, IDLE SPEED ADAPTATION, INSTRUMENTS
COMFORT WIPER (Mk IV Ibiza)
And
DTC READING/CLEARING
on >2005 models
Not an expert but learning
Chesterfield Derbyshire M1 J29
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
Fully registered hex-can-usb in manchester/oldham
Fully registered VAG COM/VCDS HEX-CAN-USB and a whole load of diagnostic gear in and around manchester centre and greater manchester located in Oldham
VCDS, ODIS, VAS PC, VAG TACHO, VAG COMMANDER, KOMFORT MANAGER. Service lights reset on all vw group cars 1999-present including long life and all other brands. Coding, adaptions, activations, Auto windows, Cluster swaps, Key coding, SKC retrieval
if you need help or advice then PM me or call me on: 07889752764.
