or sorry bud forgot to change that i have had clio sport since then and now got leon fr 1.8 20v t.
I'm looking to replace my brakes with something bigger, would like Porsche/R32 setup etc, what do you guys recomend, could this be done for under £200-300?
In a word, no. My 330mm 2-piece discs alone were over £500..
I got front CRN 312 with Mintex pads and there ok.....obviously not as good as the DS2500 but they cost a hell of a lot less.
Adam are the CRN discs a straight swap for standard?
I need new discs pretty soon, changed the pads myself no long ago but i will probably do these at the same time for better ones.
does Badger5 stock discs and pads to fit my car (FR 180)? Are discs as easy to change as pads?
So more like £2000 then!!
What can i do for that sort of money to make a large enough difference to make it worth while. Just about to do a cambelt change and replace a load of worn suspension bits and 2 tyres so don't have the funds to spend £0000's.
80 quid ish for crn discs, 110 for ds2500s. good setup
£80 each ?
And this is the coating like mine
What does the coating do except prevent rust, anything?
I recon i will get they discs and get good pads too. I can change pads no problem, never tried discs though.
I also dont know too much about bleeding the brakes etc.
I might buy them and get my local garage to fit them, they are cheap labour anyways.
