where can i get this surround cage? is that all i need? thanks
The Pioneer unit is the same price as the W505R.. I prefered the look of the Alpine unit so went for that!
Between the 205 and the 505 there probably isn't much difference, from what I can tell, the screen and graphics look fancier on the 505. Might be worth checking out the 502? Seems the same as the 505 but I don't think it has the Blackbird nav docking port and its slightly cheaper..
I think the sound quality is slightly better.. But I didn't suffer from any vibration before. Am going to be changing the components at some point anyway.
I looked through all the headunits when I was deciding and my final choices were the Alpine or the Pioneer unit. I do like Alpines kit and have never had a problem with it in the past so thats what swung me to the Alpine unit.
Alpine IVA-W505R headunit - £699
Alpine BMP200 Blackbird sat nav unit - £299
Alpine NVE-K200 interrupt box - £60
Connects2 CANBUS CTSST001 adapter & steering patch - £50
Seat satnav fascia and clips - around £10
RCA connecter - £0.50
Fakra antenna amplifier - £10
Plus a few hours of swearing and soldering..
Expensive but worth every penny!
Plus I had to buy the top heater fascia part at £27 because I damaged mine..
Yeh, I think that was the patch for the steering controls.. I plugged it in.
Yeh, I'll label it up for you when I get back from work. The interrupt box should work on any Alpine headunit with a standard AI Net input.
The feed from the OEM bluetooth is labelled on the quadlock coming from the back of the OEM headunit.
This is the sticker on the top of my OEM head unit..
Just need to extract the Tel AF+ and Tel AF- and solder those onto an RCA connector. The take the Tel Mute wire and attach that to the Alpine interrupt box.
