brakes
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Quite simply....No mate. The carriers would need milling down to fit, which is costly so aint worth doing at all unless there a seriously big set up, if there only 312mm's then not worth it at all
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
Firstly, what are you looking to buy? An ibiza or a Leon? You've posted in both forums, and asked a question.
Leon Cupra brakes wont fit the Ibiza, without spending alot of money, more than would be worth.
Cupra R engine wise,
2 versions on the Leon, as per the answer you got.
Ibiza: 1 version 180 ish brake.
Same engine as the normal Ibiza Cupra, which is 156bhp, but the Cupra R has a differently setup ECU.
After Remapping either of the Ibiza engine's, you'll get the same result of around 200+
