MOT time
Feb 28, 2008
3,990
Scotland
Mot time is upon me and i worry its gonna fail on rear tyres being too low on tread, i take it i could swap to steel wheels and put it through on them, see im gonna buy tyres but this next month packs everythin into it, MOT, Insurance renewal, and the tyres i wanted to buy, but money it the issue, i have the money for the insurance but not enough to buy tyres, so putting things into Priority MOT and insurancwe come first, so u reckon i should chance the wheels as they are or swap to steelies and play it safe?, what else should i watch for in my MOT? what height should my beams be set at cause im also worriesd about those, i seem to blind cars in front so much that i have seen 3-4 pull in to let me past, oooops......
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
If your lights seam to hight try puting them in number 1 instead of 0.
Are the rear tyres down to the wear indicator yet?
Feb 28, 2008
3,990
Scotland
i dont even know if i have a wear indicator on the tyres to be honest lol, see i asked the guy at a tyre shop n he said they need changed but he only looked at the and guessed didnt actually check the tread , i think my lights are dipped at the lowest setting mate, will have to check
Damoegan
Oct 15, 2007
8,993
Newcastle
Lowest light setting is 0 I think so try the next one up.
You will deffo have a wear indicator on them mate. Guy from tyre shop could just be trying to get some cash out of you....
You can buy a tyre depth gauge for a few ££ to check your self..
the tyre bloke probally looked at the wear bar on the tyre to check if there legal when i was a mechanic i could look at a tyre and tell if its legal or not without checking the limit with any tools as when your in the trade its a skill you pick up i guess.
it sticks with you as when i walk past an illegal tyre i can spot it so be safe and put your steels on for the mot.
dont worry about your lights as an mot tester will put an advisory on your mot check form and rectify the problem without failing the car as its an easy two minute job for a tester.
give all your bulbs a check over check your exhaust hasnt got any blows thats about all you can check really without the skills.
good luck to your car let this thread know how its gets on.
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
Many tyres will have tread depth indicator blocks which will show you when you are down to 1.6mm. If these blocks are level with the depth of the tread then you need to replace your tyres.
If your tyre has no indicator blocks, I would recommend using a 10p piece to check the depth, if the tread covers the ring of dots, then your tyres are legal.
Just place the coin in the tread from the outside edge all the way across to the inside.
Also I always fling a bit of Redex in the tank to help with the emissions part of the test.
Here is a link to VOSA form that the tester will be filling in when testing the car....http://www.vosa.gov.uk/vosacorp/repository/MOT%20Inspection%20Checklist%20%28VT%2040%29.pdf
3,990
Scotland
good little trick with the 10p, think i will put on the steelies and ssave myself a possible £35 or more, get to fell the speed of the 1.2 without heavy alloys again!!!!haha, will i get done with my number plates cause they are shorter? still legal spacing so i think they would be ok
Jan 28, 2009
703
Glasgow
you can have a shorter plate as long as the spacing is correct so would not worry about that.
things to check also: brake pads (would fail if pad has less than 5p thickness), brake disks (if they are worped in any way they will fail), anything else would be a little more difficult to assess like play in your wheels and suspension etc. lights- back and front - sidelights/headlights/high beam/indicators, back fog. horn, seatbelts, wipers. this covers most of the upset of the car. good luck scott
Feb 28, 2008
3,990
Scotland
cheers bud, i take it my front fogs will b ok, they aint wired up......u comin along mate?
http://www.seatcupra.net/forums/showthread.php?t=233841
Jan 28, 2009
703
Glasgow
yeh your front ones dont matter.
yea why not...ill be getting my 1.2 back soon, looks amazing so not sure which one ill take down lol
Jan 28, 2009
703
Glasgow
you can give your car in for an MOT 28 days before it expires so means you have almost a 13 month MOT...when is it due??also means they could pass your tyres and give you an advisory for them, just change them at a later date, but keep monitoring them to ensure ur not illegal
Feb 28, 2008
3,990
Scotland
so it failed yesterday and passed today......rear tyres, led sidelights, and he claims the xenons were 2 different colour and also neede aligned, got aligned yesterday after i changed the bulb and put in standard sidelights, they forgot to chage me for the realignment lol. and put steelies on this mornin and passed, was a bit kecktic but got there. anyways pics of my car on steelies here haha
http://www.seatcupra.net/forums/showthread.php?p=2591193#post2591193
