I've left the blue circle one unattached unbunged
Is the rest correct then?
I run my DV the same way as Mike, Ric (reversed). As do a lot of people.
Cheers mate! Are my thoughts correct (about what goes where)?
Also, removing the SAI (yes I have read your thread already) does what exactly?
Yeah rest look correct.. The circular one way valve should have a tube running to the other valve on the left hand sise of the engine bay.
Makes the engine bay tidy.
It has a pipe already with lots of junction from it. Should I replace this with a straight run of vacuum pipe then?
Remove the lot altogeather, put 1 pipe with a T in from the manifold to the DV. Use the T for your boost gauge take off.
Like this
......Can you then just leave the rest of the vacuum pipes in place. I don't want to start taking things off when they might be used for something! I'm not fussed abut stripping it all off just yet, just want the slight gains that you get from doing this.
So if you dont have a boost gauge then you wont need the T-piece near the dv would just be 1 long piece of vacuum hose? Always thought about doing this but i just cant seem to get my head round it haha
