Anti Roll Bars
Mar 29, 2007
1,207
Berkshire
Hi all,
I am currently reading into different ARB setups and was wondering if I could pick some of your brains on this one...
Digging around the Leon FAQs I came across RuddMeister's suspension guide, which was a good read and pointed to an interesting chat about ARB theory: http://www.geocities.com/MotorCity/1108/shine.html
The car in question is a different model but the theory seems sound. Please try to read the whole thing if possible even if it is a little dry. :)
From what I can ascertain, body roll is greater at the front of a vehicle (e.g. when cornering all weight is transferred to front outside wheel); and it seems SEAT put a 19mm ARB on the front of the LCR to combat this.
To reduce this roll further a stiffer (thicker) anti-roll bar should be fitted to the front of the car.
(Fitting a large ARB to the rear and a small ARB to the front seems to be a big no-no which will create snap oversteer due to the front rolling and making the stiff rear more likely to raise on one side.)
The next stage seems to be regarding balancing the rear to match the front, so if a really stiff bar is fitted up front then the rear will need stiffening up to allow the rear to keep up with the front.
What is everyone elses thoughts on this? What have you tried on your car?
The LCR is stock 19/0 (f/r) from what I am led to believe. What would a good setup be to change to: (f/r)
22/0
22/25
25/0
25/25
25/28
From what I have been reading having something like 19/28 or 22/28 would make the rear too stiff and liable to oversteer. Snappy overstear is really not something I want from the Leon and would prefer mild understeer as a predictable setup is much more confidence inspiring for me.
Just to add that I will be sticking with the OEM spring/dampers.
Thanks again for your time,
Rob.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
You can also go for 23/25 which is what i will be doing, i have the 25MM rear on along with a rear strut brace and its realy good, i think having the strut brace adds a bit more stifness, the 23mm front will be from the R32, the LC front is 21mm as standard
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Rob, think you pretty much know my thoughts on this.
I had 23mm front, 28mm rear (set on mid point) and S3 strutt brace all with new wish bone bushes and uprated engine mounts and 92,000 miles OEM springs and shocks.
I loved this set up and if it hadn't been for the coilovers coming up I would still be on this set up.
I had this set up for about 23 months and loved the way the car felt.
I never really got to explore the limits of this due to getting to crazy speeds and still not finding the limit.
There's not alot of people on here got the same set up as the above(if any) but the Octavia VRS guys swear by it. They have the same suspension set up as us.
I've just been on the track with an instructor today, I no have the above set up (with rear set to hardest setting) and coilovers, the instructor said the car felt perfect. It is very difficult to induce over steer in this set up.
Mar 29, 2007
1,207
Berkshire
The only problem I'd have with a rear strut brace is that I don't want to affect the load space when I have to carry a bike or load up the car with ikea stuff.
What made you go for the 23/25 over a 25/25 setup? Is it due to the price diff between neuspeed and the R32 part? Do you think you could benefit from the extra 2mm at the front?
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Willie , do you think the rear strut brace helps the anti roll bar at all, i thought maybe with my 25mm and the strut brace it might equate to 28mm or there abouts...maybe
Mar 29, 2007
1,207
Berkshire
I just wonder if going for a 28mm rear is a little stiff against a 23mm front. Perhaps you don't run into issues because it is adjustable and in affect is is acting as a smaller ARB on the rear. Do you think 23/25 would have been just as good a setup for your car?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Willie , do you think the rear strut brace helps the anti roll bar at all, i thought maybe with my 25mm and the strut brace it might equate to 28mm ...maybe
Yup that would be my thinking too Phill.
It's easy to remove, try a few runs to see the difference.
After being on the track I don't feel the need for a rear strutt brace.
My next stiffening/handling mod will be a cage.
Not too sold on the rear strutt brace TB but never had one fitted to see what they feel like
Mar 29, 2007
1,207
Berkshire
Also, do you think there are benefits to be had for going up as far as 25mm on the front. I don't doubt that roll will be greatly reduced with a thick bar up front, but do you think the ride would be badly affected at all? Would 25mm be better paired with 25 or 28mm at the rear? I don't want an overly stiff rear, but don't want one which lags behind the stiffened front end.
My current setup is just the standard OEM 19mm ARB, but when I added the upper strut brace I found the front end so much sharper for the better. Haven't had a problem with the backend keeping up and that's without a rear ARB. I'm really just thinking out loud but wondering whether having a rear ARB thinker than the front is really necessary.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Rob,
I asked Willie the same question about the extra 2mm and he thinks it will make the difference, and yes it is the cost of the neuspeen that made me choose the R32, also the rear strut brace i have can easily be removed if i want to use the boot. (no tools required)
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Not too sold on the rear strut brace TB but never had one fitted to see what they feel like
I have had the strut brace for a while now and really noticed the difference , but now with the ARB as well its spot on and has improved the turn in, much better feel to the steering too.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
TBH for a purely road car I think 25mm would be fine.
For my car as you said, i have the adjustability to balance things out. There is a 32mm one, lol.
I do plan to play with the settings a bit more but need to get me trained first before messing with the car because TBH just now I am the weakest link no the car.
Rob,
What you will find is that the bars stiffen the car up. With a rally driver driving the car you wouldn't need these as he can get the car to handle how he wants with the accelerator.
What the bars will do is give you more confidence to push on more.
On another point the GYE F1 Asymmetrics are fan feckin tastic on the track.
Guys in Scoobies were running 452 Falkens at the weekend were all over the place, even with active diffs etc
Mar 29, 2007
1,207
Berkshire
Rob,
Did the 23mm ARB make the ride less comfortable. I think I'd prefer to go 25mm front if the ride is fine. Quite good with the rear strut brace being removable then, but I've never felt the rear needed stiffening in the same way as the front. The front strut towers seemed to wobble or move when pushing on, which the front brace sorted out nicely. I guess rear strut braces must have uses in certain cars as nissan always use them in the 300 series.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
I did notice the stiffer front end did magnify the weaker points of the OEM suspension
Would worry that a 25mm would do so more
Mar 29, 2007
1,207
Berkshire
Rob,
Yeah I read that there's a 32mm one - now that will be stiff. That's the great thing about those track days, really getting to learn about you and your car. :) If I went to 25mm front would have to consider whether 25mm or 28mm rear would be a better match (considering that my car currently handles great with a 19mm front and no rear ARB).
Yeah wouldn't fancy budget tyres out of choice. You thinking of trying out some track tyres, maybe on a second set of (lighter) wheels?
Mar 29, 2007
1,207
Berkshire
Mmm more food for thought. Doesn't the ARB also help to spread the loading to the opposite side in a way that simply putting on harder suspension doesn't?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup these F1's will only last for the next track day, I will then fit R888's:):)
I hope to buy lighter alloys at some point but I have two sets of alloys just now so one with winter tyres and soon to have one with R888's
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
is the rear strut brace a worthwhile mod (noticeable), i have whiteline rear arb at the minute....
pennies really arent they in comparison
Mar 29, 2007
1,207
Berkshire
I'm sure I'll be asking these questions for a while as the SCN forum hasn't got quite so many members with different ARB setups to dig out of the search...
Willie, with the 23mm ARB how much roll do you get now out of interest. Is the roll anyway reduced to s2000, lotus levels or does it still lean a bit too much for you?
Edit: Basically my aim is to find a front ARB that reduces the roll to a level that I'm absolutely happy with, then get a rear ARB which matches nicely to the front.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Yup, body roll with my set up was virtually zero before fitting coilovers
Very very confidence inducing.
As I said, if the coilover hadn't come up cheap I would be using the OEM plus ARB' + Strutt brace set up on the track for a while.
Knockhill used to have LCR in standard forum as track cars, they now have MK2 Leon Cupra's.
There was a guy on here that used to track a LCR with OEM suspension, no ARB's or strutt braces but with bigger brakes. he never felt the need for the above
