classy6
Hiya guys,
I've registered to this forum not because I drive a Seat but because there seems to be a wealth of information about the K04 turbo on here and I'm struggling to find answers else where... hopefully someone can help!
Basically I'm dropping an AMK 20v turbo engine (s3 2001) into a mk2 golf. Whilst rebuilding the engine and inspecting the turbo, I found out it's knackered. It's fitted with a K04 023 - with the hole for for the exhaust gas temperature probe.
Because the turbo is cracked and damaged (excessive bearing play) I'm looking for a new K04 023 - these however seem particularly hard to come by.
On the up side, I've found a few K04's without the housing for the exhaust temperature probe in the turbo and I'm wondering, if I run it without if it will have a major detrimental affects on the engine running?
On top of that, the actual connector/circuit board attached to the end of the probe has melted so I'm in need a new one which is about £140 which I could really do without...
If it's essential input to the ECU control? looks like I'll have to hold out or bite the bullet with a new one. If it's just another actual value though maybe I can run it without? Resistor maybe?
If anyone has any ideas on the matter, or a relative K04 023 turbo for sale... would very much appreciated as this issue is holding me up!
Edit: I've found out that the readings taken from the EGT are used to adjust fuel quantities & alter timing to lower EGT's so it's looking like quite an important sensor! Anyone run one without though?
