Hi Guys,
Wondering if you can help.
I have a Leon Cupra 1.8T 180 with Performance Torque remap and seem to be having some boost (i think) problems. Around 3200rpm i can hear and feel a flat spot, the boost sounds like it drops, then comes back about 3800rpm. I think the same happens around 4200rpm too. Seems to be surging maybe???
Anyway, just done some logs in the really hot weather, see what you think.
Much appreciated.
Much appreciated.
Code:
Thursday 2 July 2009 20:07:45
06A 906 032 MJ 1.8L R4/5VT 0003
Group A: '118 Group B: '032
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME -10.1 -10.1
Marker STAMP /min °C % mbar STAMP % %
85.69 2400 41 95.3 1430 86.35 1.7 -10.9
86.9 2760 43 95.3 1880 87.51 1.7 -10.9
88.11 3120 45 83.5 2140 88.72 1.7 -10.9
89.31 3480 47 77.6 1910 89.81 1.7 -10.9
90.42 3840 49 78 1940 90.93 1.7 -10.9
91.62 4160 51 79.2 1980 92.2 1.7 -10.9
92.74 4480 54 78 1910 93.34 1.7 -10.9
93.85 4760 57 78 1840 94.45 1.7 -10.9
94.95 5000 59 77.6 1800 95.55 1.7 -10.9
96.16 5240 62 76.5 1750 96.66 1.7 -10.9
97.36 5480 63 75.7 1720 98.03 1.7 -10.9
98.6 5680 64 74.5 1670 99.17 1.7 -10.9
99.68 5840 66 73.7 1650 100.18 1.7 -10.9
100.69 6000 66 73.3 1630 101.3 1.7 -10.9
Code:
Thursday 2 July 2009 19:59:11
Group A: '115 Group B: '031
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
Marker STAMP /min % mbar mbar STAMP
87.7 2240 106.8 1770 1310 88.21 0.992 0.961
88.82 2480 139.1 1760 1690 89.5 0.836 0.789
90.1 2760 145.9 1790 1810 90.63 0.75 0.743
91.22 3040 148.1 1830 1850 91.83 0.75 0.758
92.35 3320 149.6 1830 1830 92.93 0.75 0.75
93.44 3600 151.1 1840 1830 93.94 0.75 0.758
94.54 3920 149.6 1890 1860 95.07 0.75 0.774
95.78 4240 146.6 1880 1880 96.41 0.75 0.782
96.96 4560 142.9 1840 1850 97.57 0.75 0.75
98.18 4840 141.4 1810 1810 98.79 0.75 0.719
99.37 5040 139.8 1780 1790 99.88 0.75 0.719
100.49 5200 136.8 1740 1750 101.12 0.75 0.711
101.78 5360 133.8 1710 1710 102.44 0.75 0.711
102.99 5560 132.3 1670 1690 103.51 0.75 0.711
104.1 5720 126.3 990 1610 104.71 0.828 0.938
105.31 5520 12 990 1050 105.91 1.991 1.047
106.42 5360 12 990 1040 107.01 1.991 1.047
107.7 5320 118.8 1740 1500 108.3 0.992 1
108.83 5560 133.8 1570 1690 109.36 0.75 0.665
109.94 5720 121.8 1540 1550 110.53 0.75 0.672
111.04 5880 124.8 1610 1560 111.65 0.75 0.688
112.25 6040 125.6 1610 1600 112.87 0.75 0.68
Code:
Thursday 2 July 2009 19:55:13
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME
Marker STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.01 2320 8.36 6.7 24.8 0.6 0 0 0 0
1.2 1960 4.92 3.9 3 1.81 0.8 1.5 2.3 3
2.4 1360 24.42 78.4 11.3 3.11 3.8 0 1.5 2.3
3.68 1560 29.86 89.8 8.3 4.22 3 0 0.8 1.5
4.82 1760 36.25 100 10.5 5.43 0.8 0 0 0
6.02 2000 43.86 100 9 6.53 0 0 0 3
7.03 2200 56.33 100 8.3 7.63 3 0 0 3
8.14 2440 70.94 100 3.8 8.81 3 0 0 2.3
9.42 2760 88.08 100 5.3 9.96 2.3 3 3 5.3
10.55 3120 109.69 100 3.8 11.06 5.3 6 6 8.3
11.66 3440 105.39 100 5.3 12.16 5.3 6 6 8.3
12.76 3680 115.78 100 6 13.37 5.3 5.3 6 7.5
13.87 3960 124.89 100 6 14.47 4.5 5.3 8.3 10.5
15.16 4280 128 100 3.8 15.77 7.5 5.3 8.3 10.5
16.28 4520 130.78 100 6 16.91 7.5 4.5 7.5 9.8
17.49 4720 133.53 100 6.8 18.01 6.8 4.5 7.5 9
18.61 4960 139.97 100 12.8 19.22 6.8 7.5 6.8 9
19.8 5200 147.06 100 11.3 20.32 6 7.5 6.8 8.3
21 5360 141.33 100 11.3 21.6 6 6.8 6 8.3
22.13 5520 143.47 100 12 22.73 5.3 6.8 6 7.5
23.32 5680 148.22 100 12 23.85 5.3 6 5.3 7.5
24.44 5800 147 99.6 15.8 25.05 4.5 6 5.3 6.8
25.66 5920 148.47 99.6 15.8 26.24 4.5 5.3 4.5 6.8
26.81 6080 149.19 99.6 17.3 27.47 4.5 8.3 4.5 6
28.07 6240 151.67 100 17.3 28.68 3.8 8.3 3.8 9
