r2d2hp
Hi All,
Soon after I bought a MK3 2002 a 1.4 MPI Ibiza the coilpack blew and took out a fuse. Replaced Coilpack and also leads as the ends broke in the coilpack.
Had ECU error codes removed but as soon as the car is driven they Engine Management light comes back on.
It does not come on at idle after being reset
These are the error codes
Sunday, 22 February 2009, 10:53:17
VAG-COM Version: Release 409.1-US
Control Module Part Number: 6K0 906 032 AC
Component and/or Version: ME7.5.10 4192
Software Coding: 00001
Work Shop Code: WSC 06402
2 Faults Found:
17756 - Ignition Coil Power Output Stage 1 Open Circuit
P1348 - 35-00 - -
17757 - Ignition Coil Power Output Stage 2 Open Circuit
P1349 - 35-00
Car drives fine so am confused with what the error codes are trying to tell me. Where is Output stage 1 and 2 and if open ciorcuit would you expect the car to drive.
Hope someone can advise what the problem is
thanks
2 Faults Found:
P1348 - 35-00 - -
P1349 - 35-00
thanks
