Coilovers, advice?
Timm
137
Notts
Hi
I know this has been covered before but i run some searches and not really found the results i was after
i'm thinking of getting coilovers for my FR (2008)
which ones are the best to go for?? how much?? etc...
its got 20k on the clock so is there anything else i'll need to change??
as you can tell i don't really know much about this so your help would be great!
Timm
137
Notts
around £350 mate. V-Maxx look like the better option to be honest, what are people's feedback to them??
i read about a week back that because there 20k on the clock there may be a part that will need replacing??
May 29, 2008
675
Aberdeenshire
i recently put on Jamex coilovers Cant fault them plus the price was good!......put for the extra go with the recommendations like of V-max.
My car was sitting just under 40k so i replaced the top mounts too
Timm
137
Notts
i'm going to go the the V-Maxx, if they come in time i will be fitting them sometime next week...
are they easy enough to fit? if they are has anyone got step by step info??
DamianPM
6,389
84
Newcastle/Durham
Basically a straight swap for the standard suspension to be honest. You just need to swap or replace the top mounts and then fit the coilovers how the old suspension came out.
Damian @ DPM
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
i have weitec's and they are awesome for day to day driving. not sure about track as i have not had the chance to get the car on track..... can let you know after i been to nurburg in aug!
my car had 20ish k on it when i fitted mine and i used the mounts that were there.
Timm
137
Notts
Just ordered!! anyone know if tracking goes out once fitted or should it be fine??
Timm
137
Notts
went for the V-Maxx in the end, price isn't bad and other people reckon it does a good job :funk:
how much will it cost in general to get it re-cambered?
May 29, 2008
675
Aberdeenshire
ive heard very good things about the v-max kit.
to get the wheels aligned and front camber adjusted i was qouted £60ish......but thats going to a local tuning company which is always going to be expensive.....and good tyre fitter should be able to do the work!
The problem i had is the tools they use to do the camber sits on top the tyre and my car being so low, ended up being a bit of a nightmare! lol
Timm
137
Notts
reckon a normal garage will be able to sort it??
ah thats not good lol how much have you lowered yours??
i'm still not sure about the top mounts yet, i think its going to be the case of trying to fit them and see lol probably not the best way to go about it to be honest!
