Gudgie
Morning all,
quick question. at the weekend took delivery of my forge 007p and my green panel filter
. everything is fitted and working fine.
I've done a search and the only guides i can see to modding the airbox are for the LCR. Are the priciples essentially the same if i was to mod ie smooth the airbox on the LC as i know that the 2 differ.
Also was wondering about fitting a cold air feed. Is there any need to install anything that resembles tumble dryer hose like i've seen on a couple of guides or would anything around the 80mm mark suffice? Where would be the best place to source the feed from? will it make a noticeable difference to performance, the sound of turbo spool etc etc? any pros and cons greatly welcomed!
Cheers in advance!
Cheers in advance!
