6 Speed anyone/
Bora Sport
Hi all,
I am fairly new to the forum. "I come from the land down under" in sunny Queensland to be more specfic.
I own a black 1999 Ibiza Cupra 2.0 16V. It's one of only 58 that were sold in Australia I have been told. It is basically standard except for a set of KW V2 coilovers and a short shift kit.
I was wondering has anyone fitted a 6 speed gear box to a Cupra 16V? I would be pleased to get some info on the swap if so, especially which would be the best gear box option. Apologies if it has been discussed previously. I did a search but I couldn't find anything on it.
Cheers.
Dec 17, 2006
1,837
Bristol
Don't know of any 6 speed conversions into Mk2 Ibizas. I know people have put 16v gearboxes onto 1.8T blocks, so it may be possible to do it the other way round!
Bora Sport
I used to own a Golf VR6 with the standard 5 speed. Now as well as my Cupra I own a Bora V6 4 Motion with a 6 speed. I know that I am not comparing apples with apples but I sure would like the closer spread of ratios that you get with the 6 speed box in my Cupra.
A few guys here in Oz have mentioned an O2G would be a good choice. Apparently the box used in the Bora is way too heavy for the Cupra.
WeeJase
pert
Jun 2, 2001
8,595
i think there is clearance issue when it comes to fitting later 6 speeds to the mk2 .not 100% but from memory,it fouls on the chassis somewhere.It can be done,anything can be done.
with enough $$$$$
CIarkie
225
Basingstoke
The ibiza cupra sport F2 replica had a 6 speed box, not sure what they used as my old school copy of max power when its was on the fornt page is at work where i dream i owned it everyday
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
theres a guy in Sydney that a lot of the Oz boys get bits and bobs for their Seats from ,(Camden GTI Performance Pty Ltd
02 4627 3072 or 0423 051737
camdengti.com.au
you may already know of him? hes also to be found on VWwatercooled.org.au as Golf Loon) he's normally pretty good at sourcing both info and bits if your stuck.
Good luck in your quest
:D
Bora Sport
Yes, Thanks. I know of Matt and I have spoken to him. He has some ideas but nothing specific. He was taking about a box out of a Diesel Golf. However unless you could change the final drive ratio I think the overall gearing would be too tall.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Possibly not, there's a 16v on here running with a diesel 5 speed box.
