as in spooling earlier/quicker?
Forgive my lack of knowledge/ignorance on thisNo, as in you can increase the advance of when the spark fires (the timing) so that the fuel burns for longer, and you get more power from each "bang".
There are three apparent benefits - cooler intake charge, reduced EGT and ability to increase timing. But the best gains come from the increased timing one;
1. The intake charge reduction is not massive (i.e. if you have a bad intercooler, WMI isn't going to fix it, if you have a good intercooler, it's not going to make a massive difference)
2. The reduction in EGT is useful, but you can't rely on having a full bottle on a road car, and so you can't map for higher EGTs. Forget to top up the tank and it would all go wrong very quickly.
If you tried to increase the timing without WMI, you would get knock/detonation, which is the fuel igniting before it should do.
The key fact to take away is that WMI can significantly increases the octane rating (which is a fuel's detonation rating) of the intake charge, on a properly setup system.
It's like running on race fuel, but with 95 in the tank.
Octane rating of a spark ignition engine fuel is the detonation resistance (anti-knock rating)
Octane rating does not relate to the energy content of the fuel. It is only a measure of the fuel's tendency to burn rather than explode. The higher the rating, the more detonation resistant the fuel is.
Methanol is 123 Ron.
Indeed how long does it last? Furthermore how would the timings work on a deisel? Would you need different software etc...How long does a tankful of mix last?
Suppose I should go away and research![]()
Yea will do cheers D.I use my washer bottle (which I hardly use on the screen) at 3 litres. That lasts me about 250 miles at average use. Much less if heavy sustained use.
The diesel kits are different but I understand there are huge benefits. Have a look at the Snow Performance website.![]()
Get DPJ to do it for you
Toledo one is a staight swap and is 5 or 6 litres. Songman ran one.
