What are peoples experience with the uprated bushes? I realise there will be a trade off between handling and comfort. have just bought the tt rear wishbone bushes to fit rather than poly ones but is it worth having poly engine bushes and if so which manufacturer do you guy's think are best. Just want to make the right decision by using other peoples experience's.
Dogbone poly bush will stop a lot of the front wheel skipping and wheel spin as a result. You do get a fair bit more vibration though. Unless you have serious wheelspin problems I would spend the money on something else.
I have poly dogbone mount and engine mounts, the car puts its power down much better than standard but there is a tradeoff with the added vibration, not much but it is noticeable.
