Always![]()
adjustment appears to be 35-65mm front and rear. Even at 35mm is this too low for an LCR?.
Whats better of coilovers or springkits and makes?
Those will be quotes for other Mk1 Leon models not the LCR
15-20mm will be a safe drop on an LCR anything 25mm+ would be risking your undertray / sump / splitter etc on speed bumps
Cheers Rudd, I'll ask Awesome if they can be set to this height.
For anyone thinking of lowering there LCR (assuming it's for perfromance not aesthetics) consider some anti-roll bars before changing springs / dampers etc
Some info here too, which you may have read
http://www.seatcupra.net/forums/showthread.php?t=91243
Whatever you choose the #1 problem is ensuring you get a kit for the LCR not the Cupra.....the giveaway is that the front shock absorbers need brackets to take the front ARB on an LCR (Other Leon models are different design)
Neuspeed rear arb is in the works when the sun arise again in the springtime. Lets just say for the sake of argument Im not limited by budget on selecting coilover /spring kits, what would suit me better? As stated 20mm-ish lower and somewhat stiffer. Aiming for a smuuth but firm ride. Perhaps a trackday once a year.
Will a coilover kit be just to much to fiddle with and hard to set up as I might just need 10% of its potential.
If you are only doing a few track days then I'd recommend spending your time adjusting (reducing) the air pressure in your tyres rather than fiddling with the suspension on the track day - just my opinion.
So why go for coilovers?
Coilovers offer a perfectly matched set of springs and dampers and have a few other benefits too (ability to fit wider wheels, height adjustment, rebound adjustment, ability to tune your set-up etc etc depending on the kit selected). Luckily my budget allowed Coilovers and this is where I focused my search.
Sets of off the shelf Springs and dampers 'may' have been thrown together from the part bin, or may be brilliant either way not much R&D will have been done on mixed sets.
For argument sake if you are not limited to budget then follow the usual rule of thumb, spend slightly more and buy some quality, my personal preference
coilovers;-
KW Coilovers
Bilstein PSS Coilover
H&R kits are meant to be good too
Springs and dampers;-
Koni FSD shocks and Eibach springs get good review
Why just a rear Neuspeed ARB? the front end has quite a lot of weight (the engine) and a big hole cut out of the floor plan for the engine, IMO front ARB's are a welcome addition
-My understanding is that a larger front ARB will make the car understeer more hence Im only goin for the rear ARB. Again, Im not making a track car! Just want it that little stiffer and smuuther.
With my 25mm front /28mm rear arbs, I've lost pretty much all understeer.
where did you buy these from ? im after new anti roll bars an strut brace.... goin to try get part numver for s3 top strut brace an then will get new anti roll bars...
-What do you mean reduce the air pressure in my tyres? That will only lead to uneven wear and loss of performance. If you refer to the 45psi on a previous tread I wrote I would do some testing and found 33-34psi to be to soft. Mushy feel. So I run 36psi rear and 38psi front now. These are 235/40 18" BF Goodrich G-force T/A KDW II and not stock tires /seize /make so oem nrs. dont apply.
-OK, let me ask using different words: Will a coilover kit make the car TO sensitive and stiff on a normal road surface with potholes and whatnot youll find there?
