i will be running 7.5 X17 ET26 on the front and 8.5X17 ET21 rear so will see how much that rubs lol. i will be running stretch though so shouldnt be too bad.
Pretty ok, front will stick out ~2-3mm and rear will stick out 10mm aprox. (from the arch) Hope you got stiffy suspension cuz the rims will rip your arches if you got big load on back
Nah wont be that bad, shouldnt get much poke at all tbh, my FR wheels are the same offset (only 7's) so and the front will still be with the archs safly
Standard FR wheels is 7" and ET 42 . Your new rim is 7.5" and ET 26 It will stick out 22mm more than ur standard FR wheel, inner clearance is 10mm more
Good link to check what fits and how far it sticks
If its 7.5" and ET26 with original fitment, you'd need adapter to change the fitment.. And that would mean your new ET would be 6 (if the adaptor is 20mm)... Which wont fit. Well I mean they do fit but they stick out way too much. If the ET is 26 with adapter then its ok. (orig. ET 46)
I apologize my bad english
cheers, it's gonna be an et26 after the adapters, I was thinkin of having the adapters machined down to 20mm to make the et 31, i'll see what they look like first at 26
