The beam pattern with the nightbreakers is already broken, so I reckon the antiglare will help ..
looked to see wehre i was gonna fit the ballasts and thought inside the wing ontop of the wheelarch with the sticky pads...
however seen this pic
lookslike hes stuck a screw into the headlight unit.. surely thats not too good as it effectively breaks the seal of the unit?
also noticed this guys kits a 55w... one i was sent is a 35w
I zip tied the N/S ballast up near the battery & he O/S one is wedged inbetween the washer bottle pipe & inner wing.
I think the above kit isn't the Ultimate kit so it won't have the "soft" start digital ballasts & uses 55W so the ECU doesn't throw up a bulb failure.
well they're in.......... stuck the ballasts on with the doublesided pads on the headlamp like the above pic. may wack a self tapper in it aswell just to make sure it doesnt fall off.
have to say i'm muchos impressed... the light is absolutely bright white. will get some pics tomorrow
Sounds good, very interested to see what the anti-glare bulb looks like prior to me fitting mine
There you go Moley
i just fired them on with the doublesided pads which were supplied.... tempted to maybe stick a short self tapper in each ballast just to make sure they dont come off.
