i was going to0 get a whitelin arb but when i got my seat sport strut brace i didnt think id made that much diference to the handaling.... so was i worng it realy does make a diference? especialy with the colovers???
Yea, rear ARB will help reduce understeer and you will really notice that as the body rolls less. Front strut brace just stiffens the front up a bit. Stuffening the front of the car increases understeer.
Depends what you want really, but most ppl want less understeer in a front wheel drive 'road' car
Although may be thicker thicker the whiteline is stiffer when set to the maximum, they also make a non-adjustable one which is thicker....similar to the jabba one
I find the strut brace helped give more feeling through the steering and seemed to make it feel tighter. I think the heavier diesel engine might have some effect on how much difference you feel with the strut brace and also with the Rear ARB.
I picked the thicker more expensive Jabba ARB to compensate that for the understeering nature of the TDI.
They all understeer, I didn't notice a difference when I switched the petrol Cupra from the derv. Don't notice a difference with the strut brace on or off either (with rear ARB fitted). I think the strut brace effect must be very subtle, it does tighten the front up but won't actually reduce understeer. But if it makes the car feel better and more confident then that's the main thing
Didn't know it can be stiffer than the Jabba when set to max.
To be honest though I prefered the Jabba ARB as it was a solid bar rather than all the bolted joints the Whiteline ARB has. And I didn't know Whiteline had a non adjustable ARB aswell.
The strut brace doesnt relaly kick in until you are on the limit of grip I think.
20mm rear spacers is the best mod ive done handling wise really changed the car i think ive nailed the handling on mine with the
jabba rear arb
20mm rear hubcentric spacers
strutbrace
fk coilovers
pirreli p7000
cupra bushes are stiff enough and rear strut brace imo looks USELESS
and im very happy with the outcome back end is first to go before the front end and virtually no understeer even when powering out of corners but maybe my quaiffe limited slip diff helps!
dont need to imo cupra one's are stiff enough. nothing wrong with spacers as you get longer wheel bolts to get a good amount of thread into the hub! no where near unsafe unless you go for the floating spacer which imo are DODGE!
