Oil For Cupra Tdi 160
VW505.01 - 5w 40 and VW 506.01 - 0w 30 have both been replaced with the [backwards compatible] VW504 / 507 - 5w 30 spec.
All [VW and Audi] at least dealerships use the same oil for either service regime. There are a couple of exceptions (something like the V10 TDI and the RS range) which still have 506.01 or other specified.
Hello
you are right, the Mobil 1 ESP Formula 5W-30 VW507.00 are backwards compatible, so they say in
http://www.mobil.com/UK-English/Lub...l_1_ESP_Formula_5W-30.asp#SpecsApprovalsTitle
Mobil 1 ESP Formula 5W-30 has the following builder approvals:
BMW Longlife 04
Mercedes Benz MB-Approval 229.31/229.51
Volkswagen (Gasoline / Diesel) 504.00 / 507.00
Peugeot Citroen Automobiles E06-N3 / D06-N3
Also recommended for use in applications requiring
Volkswagen (Gasoline) 502 00 / 503 00 / 503 01
Volkswagen^ (Diesel) 505 00 / 506 00 / 506.01
^All VW engines with the exception of Unit-Injector / Pump-Duse TDI without Longlife Service and without DPF between 1999-2003 and R5/V10-TDi before model year 2006
