Took mine in yesterday as a bubble has appeared in the paint on the rear tailgate near to the Seat badge. Wasn't their a week ago when I washed the car.
Looks like it will blister up and then form rust. It's getting slightly larger each day with the wet/cold weather up here.
They took photo's yesterday to see if Seat would fix it under warranty. I mentioned paint issues when I first bought the car and their won't be any 'if' about fixing it as i'm severely pi$$ed off with the issue's i've had fixed since buying it, including a new alloy.
Outstanding niggles:
1. Also need to look at why the engine fan keeps coming on for a split second along with the climate panel flashing.
2. Slight clunking on the front end when turning over a rough surface.
3. Vibration noise when clutch is pressed to the floor, sounds like release bearing.
Mine (57 Cupra TDI) pulls to the left slightly but nothing i'm concerned with, feels more like it's following the camber and is not as bad as the scooby.
