N75 Race valve
Mar 10, 2005
1,439
Walton on Thames
I'm happy with mine, doesn't seem much different to the J to me reallly.
but if i was spiking at 20 and only hold 10-12, i think I'd be swapping to a J
maybe mine's working better because i had it mapped to a J
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
i will have to try make a vid of what going on with mine at the mo it flicks up to 20psi then it likse somethings let go it drop back to 15 realy realy quickly like it just let go
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
well ive been in contact with the people i got my h from of ebay because i was starting to think the valve itself eas faulty this is what has been said to me
David,
We get this request a lot and have taken returns in the past but the valve never seems to be faulty. A replacement valve will not solve the issue.
The H valve will only working properly if you are using high boost levels, if this is happening, you may need the N75-J valve which is an upgrade to the F valve. The H valve is an upgrade to the J valve.
I own a VW Golf 1.8T 25th Anniversary. The car is mapped and I put an N75-H valve on, it did work but then I experienced similar problems to yourself. I then tried the J valve and that solved the problem.
Can I ask what remap you are running?
If you would like a J valve, just let me know and we can see what we can do for you.
Kind regards
Andy
- premier-tuning
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
ive asked him if a swap would be ok, havent herd back from him yet
thats another idear i was thinking mate
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
saw a link to vagparts for a j valve do u know wot it is?
so is there a difference between the j valve and the race valve?
The 'J' is an upgrade to the standard valve and the 'H' is an upgrade to the 'J' valve. I think?
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
ive just asked the bloke about a J causeing limp mode because every one seems to think it dos and this is what he said
No mate, a J valve is used to oversome the usual limp mode that may occur with the F valve. You will not get limp mode with either the J or the H valve.
People use the H valve instead of the J valve as it holds a lot more boost and can give an extra 2-3psi but is only worth it when running very high boost.
Hope this helps.
Kind regards
Andy
- premier-tuning
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Hope this helps.
Kind regards
Andy
- premier-tuning
Well thats not 100% true is it as we know if you fit the J valve it can cause boost issues and limp mode. People have experience of it on here.
