here's what vag-com came up with exactly:
VAG-COM Version; Release 409.1 - US
Chassis Type:6K -
Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding:10500
Shop #: WSC 79921
3 Faults found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35- 1- - - Intermittent
16486 - Shareware Version. To decode all DTC's - Mass Air Flow Sensor (G70) : Signal too low
P0102 - 35-00 0 Please register/activate
18010 - Shareware Version: To decode all DTC's - Power Supply Terminal 30 : Voltage too low
P1602 - 35-10 - Please register/activate - intermittent
Readiness:0000-0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding:13404
Shop #: WSC 00000
1 Fault found:
01314 - Engine Control Module
79-00 Please Check fault codes
