Feel like a loose wheel
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Ive noticed some odd noise coming from the left passenger wheel, every time i go over a ramp and as i come off it, feels like the wheels wobly as its guna come off :(
Dont have a clue what it is or what to look for. Any suggestions ppl? :confused:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
If it feels wobbly, jack the car up and spin the wheel. See if the wheel is buckled or the tyre is distorted. Either that, or get a mate to follow you at low speed and watch the wheel.
Big_daddy
Oct 20, 2006
3,930
Brummy
Cheers, give that a shot, waiting till the weather gets better or the rain stops.
Could this also be a cause of a worn bush of some sort. The whole suspension been changed quite recenty and the problem was there before that.
Big_daddy
Oct 20, 2006
3,930
Brummy
just popped for a quick check, started p155in again,
So far i checked the nuts and they tight. Ive tried shakking the wheel but it firm, tried spinning it but it spins for a second then stops.
When a new suspension is fitted is it recommned to get tracking done?
You need to look at it from the back when you spin it....
Big_daddy
Oct 20, 2006
3,930
Brummy
some thing odd happening, Kep getting this private message
Hi Big Lad,
The post that you created in the following thread has been edited
Post: Ive noticed some odd noise coming from the left passenger wh...
Thread: Feel like a loose wheel
Reason:
This is an automated message, please do not reply.
Regards,
The SEATCupra.net Forum
D.K
LCR 225
Oct 24, 2007
6,408
se london
Yes if youre changing any part of your suspension changed you should get the tracking checked
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Hi Big Lad,
Reason:
Regards,
That's the fault of some noob moderator. :hide: sorry.
Big_daddy
Oct 20, 2006
3,930
Brummy
Thats gona be hard, to spot, the front disc dont allow the wheel to spin that freely,
What if i swop the front wheel with the back?
Jochen
Hi,
Worth checking your front antiroll bar bushes are not worn? this causes noises when going over bumps.
Jochen.
Big_daddy
Oct 20, 2006
3,930
Brummy
Hi,
Jochen.
This is something im not quite good at spotting, ill give it a shot and all the suggestions the others have mentioned
Romeoisgraham
Mr Harris
Aug 14, 2007
842
On the run
public.fotki.com
any alterations to suspension should require a tracking check, even pot holes can put your tracking out!!!
Big_daddy
Oct 20, 2006
3,930
Brummy
Just had it took to my local garage, he jacked it, and checked he said it seems fine. Next job is to get the wheel balanced checked and then have the laser tracking done.
Glad its nothing serious
