thats great mork, cheers
does anyone know if i can ditch the whole oil to water cooler? the square ali unit that the oil filter seals against.
i want to loose it as im going to run the mocal sandwich plate and cant see the use of it.
just wondered if anyone knew if it did anything other than cool the oil?
im aware i will need to make a new oil filter feed pipe/mounting bolt
thanks
Yes you can ditch it, have done this before (on my vr also) as they can be problematic, just needed to shorten the shaft iirc, best done on a lathe
The mocal will be more than sufficiant (13row) on the 1.8t, so you can ditch the stock one and yes all it does is use the water jacket to cool the oil, which in turn heats the water
I know someone who builds 1.8ts and races them in the VW cup who would prob build it for you, very worthy of course, but would be a 'build' and not necesarily a machine
shop if you get what i mean?!. He's in Essex.
