Got hold of an oil pressure gauge for free!
But what fitments do I need and where can I tap it off from?
Where do you wire an electrical one into?
I think the one I'm having is this one.....
with the kit that you could get as a factory option they had a sender unit that went into the top of the sender plate and had a second plug on top that you tapped onto. this then led back to the gauges that you just plugged in.
Well worth knowing, even if it is only when you sense something is wrong, at least you can check.
Like a double connection? Were the extra option gauges mechnical or electrical?
