Anybody had this rattle?
shaunw
103
HANTS
My Leon has developed a really annoying rattle. It sounds like its coming from the underneath / back of the car on the passenger side and happens when going over bumpy roads at low speed. If you hit a a pump it sort of goes ddddrrrrrrrr. I presume something might be rattling against the floorpan.
Havent been able to get underneath to have a good look around yet. Anyone experienced this and found the cause?
Regards
Shaun
ste-lfc
256
cheshire
yeah m8 i got this too,i traced it to the 2 rubbers holding exhaust up in the middle,i pushed them on a bit more and was ok for a bit but its back now,:shrug:i got a heat shield rattle now also,service due soon so will get them to fix it then.
cupra2007
RCOTY
Jan 7, 2007
193
rhodes/greece
the same for me,2 rubbers, but fortunately didn't came back,so far :) !what i have now is a noise like the boot isn't closed properly.they checked it at seat and haven't found something!!at the service(15000km) i'll make them have another look.cheers!
Rob66
1,620
93
UK
Cupra2007
Pull the back seats forward and wrap insulating tape round the metal retaining clips on the bodywork - this will form a tighter fit when the seats are pushed back into place and hoepfully stop the rattle. I had the same thing and this sorted it out, you will need to replace the tape every 6 months or so.
regards
Rob
cupra2007
RCOTY
Jan 7, 2007
193
rhodes/greece
Cupra2007
regards
Rob
unfortunately i've done it,also on the clip of the boot!it's not from there!seat people cheched the lock and it was ok,its really-really strange because when you hit a bump the noise is exactly like the boot isn't closed 100%!they said that at the service they will open all the plastics from the rear and try to find it.:shrug:
Gib83
Neeow!!
Mar 3, 2007
334
Sheffield
I had a similar sounding rattle and it turned out to be the CD storage holder just behind the centre armrest. I too thought it was something at the back of the car.
CBRED
69
durham
mine is the heat shield also.rattles like hell.
when i first got the leon it had a loud bang at the rear.turned outto be the spare tyre was not fastened down .easy fix thank god.
Aug 16, 2007
666
Wolverhampton
Has anyone had any luck fastening the heatshield back tightly? I have a very similar sounding rattle but I don't really fancy a trip to the dealer...
Muesli
I had the same knocking like the boot wasn't properly closed on my last car (Audi tt) and all it needed was the rubber bump stops to be unscrewed a couple of turns. That then creates tension on the boot latch instead of it flapping around when you go over the bumps.
Worth a try along with everyone else's suggestions!
