I have had an intermitent issue over the last couple of weeks when starting the car from cold that the idle seems slightly irratic and almost a misfire that clears as soon as you touch the accerlator.
This morning, same thing happened but nothing happened when I pressed the acclerator (other than more misfire and a cough) Straight away the coolant sensor light came on accompanied by 3 beeps. I switched off and restarted and problem disappeared. No other warning lights. (car smells rich when this happens but I think that is to be expected with a misfire)
I've done a search and found that cleaning the prongs on the coolant sensor may fix the coolant sensor light but would a faulty coolant sensor also cause a misfire or is the coil packs (never a problem when warm) or cold start system?
