What carriers do I need to fit a set of willwood 4 pots to a mk3 ibiza???
I have come a cross a set that I can get cheaply but not sure what else I will need??
The car is a 1.4 is that helps.
Kind regards,
Alex
If theyre the same hubs etc.. as the cupra this will work...
http://www.edition38.com/forums/index.php?showtopic=123446
you need a lot more than the carriers.
i have looked in to this a fair bit and it seems that us 1.4ers need a whole new hub, bearings, callipers, carriers, and if your going for big brakes a new master brake cylinder.
i highly doubt you would ever need willwood 4 pots to stop a car that can just about reach 105mph.
try and find a 280mm brake conversion as these suit the weight of our car and stop well. (this is the setup im looking for)
I thought you had a cupra anyway.
I have a cupra aswell,
Both in the same colour
nope its obvious its a 1.4 due to the front bumper and rear bumper. yes they are colour coded but so are his bump strips meaning that its a 1.4 .
anyway, i know the 1.4 does not have 280mm brakes because i also own a 1.4 and i am looking in to doing this upgrade after christmas when funds allow me to.
and i know the 1.4 hubs / carriers are a 1 peice because i stuck me head under my car last night and had a good poke around to see, and sure enough... its a 1 peice jobby.
if you are finding it hard to get cupra hubs, the VW G60 shares the same front brakes as the cupra so they are also an option.
