Jabbasport induction kit
KP
Down-N-Out
Mar 11, 2007
131
Bristol
Hello People
Just bought a jabbasport heat shield from their induction kit off the bay, just need to buy the filter and breather, does anyone know the diameter of the filter and what size breather i need?
KP
Down-N-Out
Mar 11, 2007
131
Bristol
I measured the bore of the breather pipe yesterday (25mm), could a breather filter fit inside of the pipe or would the decrease in bore diameter cause to much of an odstuction? I only ask because i would like a Green filter and breather and the largest bore they do is 20mm.
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
Putting it inside the pipe you'l not be able to secure it properly mate. Breather filters dont need to be the same make as the air filter mate just buy one that fits. I use the Raid one as thats the only one i found that did one big enough
KP
Down-N-Out
Mar 11, 2007
131
Bristol
Hello people
Quick question, does the jabbasport kit come with any air ducting? Had a quick trial fitting and it seems that you need to get rid of the standard ductng to fit the heatshield.
Oct 31, 2006
870
Cambs
No ducting comes with the kit, Yeah you need to remove the standard cold air feed for the airbox to get the heatsheild to fit, be carefull as the standard pipe goes through a foam block on the inside of the wing, mine came out eventually after a bit of tugging;)
KP
Down-N-Out
Mar 11, 2007
131
Bristol
Ok cool
Where does the cool air come from if not ducted?
Does anybody run ducting with this kit?
KP
Down-N-Out
Mar 11, 2007
131
Bristol
Quick question, does anyone know whether a 45 degree silicone pipe could replace the flexable pipe on the jabba induction kit?
