Throttle Body
Feb 20, 2005
3,476
Telford ay it...
On that photo...
Follow the top right radiator hose to the coolant flange (bolted to the head). A smaller pipe comes off the flange from the right. This goes up to the throttle body, circulates around then exits up to the top of the expansion tank.
Mine goes from the flange straight to the bottle :)
Sorry i havn't put pics up yet :lol:
Thats the route it takes on the 2E.......i think
2E's are better :p
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
How dumb is this.... I'll do this on Saturday, easy enough to do with a couple of new clamps - less fuss is best
fresh_creps
166
Bedfordshire
There any tutorials on the site for cleaning the throttle body?hada a quick look and can't find anything,would quite like to clean mine to see if there's any improvement
F2 Ed
now has VAG com
Nov 5, 2006
920
www.superlite-wheels.com
Easy to hook up the hoses. Just insert abit of copper pipe and hose clamps. Pic on first page, follow the hose from top of coolant bottle.
Car seems less boggy after an hour on the motorway when its not being warmed by your coolant but otherwise dont really notice the difference.
F2 Ed
now has VAG com
Nov 5, 2006
920
Got the dremmel tool out this Sunday and did some porting and polishing work :)
Loads better ;)
F2 Ed
now has VAG com
Nov 5, 2006
920
Idle is just as it was before. Took me about an hour, not a hard job though. Worth doing i thought :)
That induction pipe is pi*sing me off abit though. Where it bends before the throttle body it tapers down loads. Might get abit of samco hose that stays the same internal diammeter.
Pedro
But isn't the throttle body diameter smaller, hence the taper?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's where it kinks in to clear the brake fluid reservoir
I'm mid way through working out what I need to replace that lot - just need a crank case filter really
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
do you know what diameter it is off the top of your head?
45 deg bend, hose joiner, straight join piece (maybe a bellowed piece to take out the mismatch on bends)
