im thinking abouth getting a remap from jd-engineering
by reversing the dv! does it loose pressure as its pressing againts the spring?
No, I run mine reversed. The boost pressure faces the spring directly. No loss of pressure.
Cool! Guna try that 2morow with my forge! see what sound it makes, abit bored with sound it makes now
Just go "weeeee tssssscccchhh" as you change gear. You'll have an infinite number of different noises as you'll never be able to do two the same.Cool! Guna try that 2morow with my forge! see what sound it makes, abit bored with sound it makes now
Just reversed it!
sound similer to evo dv, like whistle in drain pipe!
Does this cause abit turbo lag on 1/2 trottle?
plus im running the standard spring, should i be using the 2nd or 3rd one as they stronger??
Could be worth a try, might give it a go!
If you think about it, fitted normally, you have boost pressure pushing against the side of the piston. It takes the vacuum to lift the piston to release the pressure.
Running reversed, the boost pressure is pushing against the base of the piston. Once the vacuum starts to lift the piston, boost pressure will assist it. I'm sure you get a quicker release that way.
