how to get the best turbo sound
mrcoyote
See no evil...
Jul 26, 2004
2,624
Cool! Guna try that 2morow with my forge! see what sound it makes, abit bored with sound it makes now :D
Just go "weeeee tssssscccchhh" as you change gear. You'll have an infinite number of different noises as you'll never be able to do two the same. :p
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Just reversed it!
sound similer to evo dv, like whistle in drain pipe!
Does this cause abit turbo lag on 1/2 trottle?
plus im running the standard spring, should i be using the 2nd or 3rd one as they stronger??
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Just reversed it!
It shouldn't cause lag. Forge say there is no difference. Looking at the design of the valve, I think it's the logical way to fit it. I used a yellow spring with Revo Stages 1 & 2. I had problems before fitting the spring.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
If you think about it, fitted normally, you have boost pressure pushing against the side of the piston. It takes the vacuum to lift the piston to release the pressure.
Running reversed, the boost pressure is pushing against the base of the piston. Once the vacuum starts to lift the piston, boost pressure will assist it. I'm sure you get a quicker release that way. :shrug:
Big_daddy
Oct 20, 2006
3,930
Brummy
Well ive revesed mines back to normal, i prefer standard sound as it louder. plus the sqeek sound only is nice on heavy trottle, but sounds abit funny when crusing on sligt trottle. :blink:
hey some ppl prefer it and some dont. ;)
Aug 29, 2006
822
Poole
You havn't got a pic of this by any change have you?
