Right due to unforseen circumstances I'm now bench building an engine for my Cupra, will let everyone know what's happened fully in due time when I've got the motivation to strip it down further and see what is actually dead... but it's looking like it dropped an exhaust valve on cylinder 3 and possibly took the VF34 with it.
Any how, just got myself a spare engine, an AGU 150bhp engine out of a Golf and fortunatly for me they run a largeport head an 20mm pins as standard, so the rought plans plans are;
- One Piece Valves
- Forged Rods
- Forged Pistons
- 1900cc Conversion
- ARP Bolts
- General Rebuild
- Baffled Sump
- Oil Cooler
The question are, for a 1900cc conversion whats the best route, a eurospec crank and standard sized pistons, or a bore out using JE pistons? Which pistons do I go for 82.5mm or 83.0mm? Don't want to leave the bore wall's too thin! I know aftermarket pistons don't have any skirts on them so they'll rattle when cold but what they like when warm, and whats life span like on them?
Valves, rods and pistons... what options do I have available and at what prices? Seen quiet a lot of talk about SCAT rods and Supertech valves. Is it worthwhile fitting some titanium tapered guides?
And finally, what other bits would you replace whilst the engines in bits, it's "aparently" done 40k and the clocks with it say 40k but I'd rather not take any risks and replace anything that's viable to do. So should I replace the valve stem oil seals, all gaskets, valve guids... what about bottom end bearings and shells??
Any help is much apreciated, please feel free to post up what your running, and also let me know what you replaced whilst you had then engine in bits...!
Ta!
- One Piece Valves
- Forged Rods
- Forged Pistons
- 1900cc Conversion
- ARP Bolts
- General Rebuild
- Baffled Sump
- Oil Cooler
Ta!
