as i am 1 of the few with the pre facelift cupra i was thinkin something that looked like the cupra badge on the back of mk4 ibiza cupra, u know the squared spaced letterin, not the easist design but something that would look awsome if that badge was on the back as intend to do. i also wanted to know where u fed ur vacuum hose from the boost gauge slick as u have it in the dash already?
Wilksy, my gauges are DEFI.. electronically controlled, the boost tube feeds the brain in the engine bay the information and thats relayed to the gauge and controller unit in my centre alley console...
but in the custom dashes i will fabricate, i will wire the boost vacuum hose thou the dash (thou holes i cut into the dash itself behind the controls and etc) then leave the remaining hose tied up behind the dash for you to connect up to your engine bay. which i've been told is thou the hole that the airconditioning feeds thou...i think?
