Is the rear suspension on the Leon not the same as the MKIV Golf? If it is the it has an ARB integrated into the rear axle beam. Its still rubbish but it should have one anyway.
Ive got a lower S3 brace but when i put that in i overtightened the bolt and now it wont go tight. Cant get the old one out of the suspension arm. Anyone any ideas. Sorry to go off subject
It still seems better then the Golf i had previously though!!
Got downpipe and been thinking about the diff. I hate you guys
house sale has just fallen through
I uprated the suspension to Koni FSD's wrapped in Eibach springs, Neuspeed 22mm front and 25mm rear (on middle setting) ARB's, just had the Quife diff fitted, it finally handles like I want it to, worlds apart from the sloppy, boat like standard setup
How easy are the ARB's to fit, could i do it at home? I've fitted a couple of coilovers to various cars so the KONI FSD's should be fine.
Rear is a piece of Cake, the Neuspeed one clips to the rear beam (torsion bar) then you swing the ARB into position, drill some holes for the drop links, bolt the drop links on, bolt the ARB to the drop link
You don't have to drill holes! the Neuspeed droplinks fit to shocker bottom bolts.
