My dodgy maths calc reveals, 1.13bar x 14.5psi = 16.39 psi.
Its totaly maxed out at this level.
i see 20psi at redline on my setup (on gauge) , dont know what that equates to in 'bar' ? peak is 22psi
AM04 (stg2 form) with jabba mapDavid, what setup are you running?
Guys any chance you compare in vagcom measurements so we can eliminate gauge error.
3 inch downpipe, 3 inch inlet and an open cone filter - plus proper mapping of course, a semi-generic map will not get you over 280. Since fitting a 3 inch turbo inlet I now know that the S3 Forge TIH was restrictive because my car pulls harder and has better top end with the larger inlet, my Apexi boost controller is set to 1.3 BAR and it holds 1.1 BAR to the redline. I also found the BMC CDA restrictive too.
everybody speech of 280cv with 1.3 bar, but nobody illustrates testing
I think 280cv is to much dream, with 1.3 bar
1.3 bar in the 20vt of a friend
KW = x 1.36 = BHP
in cv http://img251.imageshack.us/img251/7905/marcosgt2xcvsu9.jpg
regards
Thank you very much for your answer, I do not try to be hard in my words, but I do not dominate very well in English.
I forget to comment, also have manifold ATP, and CDA BMC but is no especiif of ibiza mk3 is of LCR sat model, is more bigger than ibza mk3, and to have a ram air in 80mm for to take cold air of the outside
the DP in 3” I do not think possible in ibiza mk3 it does not fit
I have the similar mod than cupra-mat but I do not have 280bhp
