So which bits do the ice link plug into? And how do you get to it? Got any pics of how it all comes apart?
Since you ask.. yes I do
See in the wiring pic above there is a green and a blue multiplug.. the green is what would be used for telephone and the blue is what the multi changer uses..
The quadlock system is the big black frame which holds the individual multiplugs together as you can see below I had no CD or Tele inputs only the speaker and power terminals. You can also see the clip at the bottom. The CDC/ice>link is the empty slot on the right of this pic.
Once you are in the back of the headunit simply squeeze the clip on the quadlock to remove it from the radio, and plug your ice>link into the CDC slot on the quadlock and refit it to the radio (you can test it works before routing the wires and refitting the radio)
Routing the cable is quite easy.. i found that by taking of the plastic trim on the centre console in the passenger footwell there was a great earthing point and I took the esp blanking switch out and fed the wire up through it.
If you need any better pics jst shout and i'll take some.
G
