Mk 4 headlight removal
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
slightly off topic - anyone know how to remove the rear lights? the outside ones are easy but the ones in the boot, I just can't figure out!
oh these light can be a right b&st&rd you have to remove the two size25 torx screws from the outside of the ar as you open the boot and then you will need to get a flat head screwdriver and from inside the boot shine a light up where the back of the lights show thro and push the really strong metal clips lose. you can use a plastic trim tool to just prise the clip off from the outside but i wouldnt use metal as this could damage the paintwork
if your still baffeled p.m me and il send you some pics!
back on topic my rearlamps rarely steam up but they have dome at 1 point fogs, headlamps, rearlights all steamed up :no:
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
really
as i said i have changed quite a few of headlamps,try your dealer again they will knowabout it.but if you go back will the lamps drilled they wont change them
i would try again bud but i think misting headlights is the least of my worries:lol:
<<<<<<<<<<:rolleyes:
djjonnibgood
Seat Ibiza 1.9TDI "130"
Feb 13, 2007
50
Wakefield,West Yorkshire
On the inside of the boot lid there are 2 rubber bungs that need removing to reveal some screws.
The third screw is under the black plastic removeable cover as mentioned by Kinky Beeza.
Look in your hand book under the bulb changing section
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
when you have the rear clusters off apply some grease to the really strong metal clips, they are like a ball and socket type thing
a bit of grease on them will make them pop off really easy next time ;)
ibiza fr
72
So at least we all think seat plastic headlights are a pile of c*ap . Well if there is anybody from seat reading this, it's about time you stoped doing things on the cheap and started to make proper headlights that don't steam up at the first wisper of a rain cloud.
