swap coil 1 with another one, if it comes back on the cylinder you just changed it too you know its the coil, still coming back on cylinder 1 would mean new spark plug
i would try that before replacing all 4 plugs - will pinpoint the missfire problem
it does say intermittent tho, so you might have to drive it for a bit for it to happen again
Yeah there is no point me doing anything now until the light comes back on
Have you tried changing the 1st coil pack then? How else are you going to know it's a coil pack for sure without trying?! You don't need to change all 4 just borrow one and change the one where the misfire is.
I havent done anything yet because i havent had time plus its dark when i get in but i am just going to have to wait for the light to come back on before i try anything now
****ed coils/plugs and possibly boost leak/stuffed lambda to me. Trial and error diy stuff, no need to drive 150miles for imo.
It wont be a boost leak as i have had everything checked SO many times and the lambda sensor is fine too as we did a log on that
Im not driving to Jabba, they have been helping me over the phone
