Well after all the posts that keep being made about the chrome interior parts and peoplea asking what they look like I thought I would post some pictures of the chome parts to help answer these.
Chrome Gear Surround and Seat Sport Gear Knob
Chrome Vent Covers
as these are quite hard to fit thought I would post what Edbulter's guide on how to do it, sains he seems to be repeating himself saying it a lot in threads.
Edbutler
Another way is also to put cable ties into the grill and pull out the front then attach the chrome surrounds and put them back in. This can be complicated but saves time and effort.
TT pedals
Chears again to ED for guide and other members for answering my questions when I was putting fitting these. Hope this answers some questions people might have.
Chrome Vent Covers
Edbutler
Right... Firstly id mask off the vent indents on the dash just uncase you slip!
Take your radio and centre Tray out.
Remove two Torx T-20 screws from the left and right of the fascia and 2 i think from above (use a torch!)
IF you have climate, youll need to remove two from underneath either side of that. Either use a small screwdriver/wrench or take out your ash tray so you can get enough room to put your driver in.
Take the fascia out. Unplug the Rear demster and airbag light.
Now with the whole lot out, theres now space to get your hand into the centre vents. Use your fingers or be careful with a screwdriver to pop the vents out by pushing them toward the rear of the car. When theyre out you can use a screwdriver to gently unlip the surrounds.
When youve done, make sure the vents are straight and the small lip on the chrome surround lines up with the one on the dash and simply push in untill it clicks, guiding it in correctly with your hand behind the dash. If you come accross resistance at this point, the vent is not quite aligned with the rubber pipe so try giveing it a wiggle!
Then re-assemble your dash.
TT pedals
