ok got a bailey dv30 dirt cheap and fitted it to my lcr.ever since i have done this the wastegate chatters every now and again.is this cause the bailey uses a progressive rate spring which might be a bit stiffer??before i fitted it i tried pushing the piston inside the dv up and it seems alot stiffer than the forge 007p with a yellow spring.
