hows about>>
EIP VW Street Series Dual Mass Flywheel Clutch Package
The Street Series is designed for aggressive enthusiasts with basic bolt-on performance items or mild forced induction.
240mm 6 PUCK Combination metallic / fiber material disc, solid center, modified pressure plate. For use with the stock dual mass flywheel.
$699.99
http://www.eiptuning.com/eip/a4_r32_02m_clutches.html
not a fan of EIP from their service point of view, but they list 240mm dual mass
also from SPEC:
http://www.specclutch.com/
searched under audi tt
INSTRUCTIONS
Select your correct Make, Model & Year from the list below. Then check the appropriate Stage & Flywheel Combo.
Click 'Buy Now' to place your order.
For Stage & Flywheel product descriptions click here.
Audi - TT
Application Flywheels Aluminum Pressure Plate
Year Span Engine Includes Steel Aluminum None Option None
2000 2004 1.8L 6sp,5sp quattro SA81S SA81A
Pricing: $419 $479 $
Choose Your Application Here
Performance Kits
Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None
Product Number: SA871 SA872 SA873H SA873 SA873F SA874 SA875
Torque Capacity: 325 385 430 450 590 450 650
Pricing: $529 $619 $689 $649 $799 $649 $739
Choose Here
Comments:
Remove rotating mass with our lightweight clutch option for $79! includes slave cylinder
