chatter noise
ian_cupra
just been reading through a few threads, my ibiza been chattering on boost, what could the problem be??
changed most the boost pipe today for forge stuff!
only other thing i can think of is the DV??
any help please as i know its not good for it???
cheers ian
ian_cupra
i already have a forge one, had it for about 16 months now,
cars been sat for 4 and half months though, so wondering if its seized or summin????:shrug:
ian_cupra
done leak test and DV is fine, checked all the hoses and it all seems ok,
i've got no idea now, all can think off is is the exhaust is blowing slightlyjust behind the cat, thought it could be that blowing when on boost? but think am just clutchin at straws!!!
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
if its not a normal sound then theres bound to be a leak somewhere either in the turbo plumbing or in the exhaust..but you said it sounds like chatter...so wouldnt be exhaust
ian_cupra
just annoying me now as cant find what it is, when get it on a ramp cant get it to do it as not any load on the engine, only does it on boost and on load,
its a difficult noise to describe, it sounds like air being released from somewhere but in pulses, very quick pulses
ian_cupra
performance doesnt seem to be affected. although its had been off the road for 4 and half months! its fairly loud, can hear it outside quite loudly.
May 2, 2006
2,758
the sound you are describing when on boost sounds similar to my problem last week, was only getting noise on boost, not on idle so ramps were pointless
are you losing pressure just after peak boost?
mine was and it turned out to be turbo to manifold gasket, didnt chatter though, just made the noise you described on boost
just a thought .........
ian_cupra
that could be it you know, as had it off while it was off the road as the head gasket had gone!
cheers will have to have a look at that then
ian_cupra
not really, some days it seems to not even make the noise but then otheres its really loud
ian_cupra
sorted it now!!! YAY :D
was one of the bolts for the turbo to manifold! ya could move it with your fingers was so loose!! tweeked them all up now and its fine!! cheers for all advise!
was your picture that made me look smithy, cheers mate
ian_cupra
its the manifold to turbo one, theres three there, just behind the head ya can see em
