seen it loads b4 on alhambras leons they work now and again.
fiat multipla 1.9 td ones are good though
You mean the valve from the Fiat fit on the 1.8T?
yer from multipla,alfa 147 diesel and mitsubishi carisma diesel
yer there all exactly the same plug fitment hose fitment and mounting fitment
just difertent internaly all made by pierburg
or just do away with it altogether
ive run a bleed valve on one b4 o.k. much fun
nah i had this problem before on an alhambra tracked it down in the end to the wastegate sticking
test the actuator with a mityvac to see if it holds vacom if o.k. take off turbo to see if its carboned up and clean it out
nah if youve done all electrical tests and r getting no fault codes then i suspect it's down to a mechanical problem
